Electricliff
This is hardly a technical question, but someone in your group might know the answer.
I am located in the UK.
I need to pipe light over multiple paths which vary from 1 to 5 metres.
The exit aperture for the light needs to be about 2mm.
The budget is a bit limited.
Where can I source a reel of cheap light guide or fibre optic cable?
Don't need anything exotic in terms of data transmission, just need the ability to feed it through a convoluted path, put visible light (probably white)in at one end and get at least half of it out the other.
I have lots of suppliers prepared to sell me high grade megabit data cable, but at the price they are asking we might as well use copper wire with 3mm LED's at the other end.
Thanks Electricliff
Thanks Electricliff
