Lighting arrester
EngCom2007
How to use lightning arrester while receiving a signal?
OK, here is the clarification.
A digital receiver is used to receive a signal through passive discone antenna in areas subjected to frequent thunder and lightning. And lightning arrester is required to protect the equipment from damage.The question is, how to use the lightning arrester? or where/how to install the lightning arrester?
Thank you
You should get someone experienced in doing this sort of thing to prevent damage to your equipment or yourself
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
Strongly concur with IRstuff's recommendation..
There are issues in lightning protection not well understood by many.. in particular, ground shifts and the appropriate ground/bonding required to protect devices that have multiple connections, such as to an antenna system and of course, the power source.
Go to Ditek.com. They're good folks.
No, I'm not a Ditek salesman.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
