wilsonv
- Jan 30, 2003
- 33
I'm working on the design of a service for lights at a ball field. The poles are concrete and will be 70ft above ground level. The pole has a bare Cu. wire encased in the concrete and bonded to the lights supports. My questions are:
1. Should I terminate the bare Cu. wire at the bottom of the pole to a 10' ground rod and that's all the lightning portection or,
2. Should I run a ground loop back to the service.
3. Should I bond the fence/metal structures when close to the pole, to avoid any flashover?
Any comments will be appreciated.
