Jonathan Monge Cubillo
- Apr 7, 2017
- 12
Hi:
Does anyone knows if there is a way to use cold formed steel framing beams and columns like in a moment frame?
I know there is a prequalified beam to column detail in the AISI using the HSS column and the framing beam, but i have a complex project where HSS steel is not an option. Also I´m in Costa Rica, where the cost of something like Hardy Frame or Siimpson lateral force systems are likely to take down the project.
I can perform the math and detail everithing to comply with seismic lateral forces, but I´m really concern about code compliance and the real life behaviour of such a system. Especially in the conections, because there´s a high seismic risk in the country.
