pbailey
- Oct 31, 2022
- 11
I have a steel tower, approximately 7'x7'x35', that holds lime to treat min runoff. The long term effect of the lime and the structure is being questioned to determine if it has reached its service life or if it can continue to be used. Direct inspection is nearly impossible at this location. Any insight how lime affects steel after it is in direct contact for a substantial amount of time?
