Line colour code/standard for dimensions, text and equipment on .dwg drawings
Feb 16, 2012
30
Hi All,
Is there any standard (preferably ISO) which says what line color should be for the following in a .dwg drawing, thanks in advance.
Dimensions
Text (i think it is cyan)
Equipment
Existing item/equipment/structure
New item/equipment/structure
IMO, in the CAD drawings the typical colors of the text and lines are recommended in the software application and used as a default color codes. If required, the users may modify or define other colors for the specific needs.
