Distribution73
I would appreciate very much to have your opinion on the following:
I am trying to set a directional ground instantaneous element (34.5kV Line Prot. Application). The utility policy on this regard is that it should be set as "1.25 x 3Io for the maximum line end fault, with the remote end open".
I am curious about the reason behind the requirement to have the remote end open. I can see, when doing fault simulations, that the fault infeed from the end I am trying to set increases when the remote end is open. Therefore the setting I calculate is more conservative. However I cannot see any reason why I cant use the fault values obtained when the remote end is closed (more sensitive setting).
What do you think is the background for such requirement?
Thank you very much in advance.
