howearthmademe
Hi All,
I am designing a test rig for a reciprocating pump and motor assembly to obtain the system curves etc...
The problem is how am i going to increase the inlet pressure for this pump (manufacturer suggested an inlet pressure around 10psi-100psi)?
If i add a pump at the inlet say a centrifugal pump to reach the required head, what effect would that have on the performance of the reciprocating pump?
Any suggestions would be greatly appreciated!!
