A mounted set of plates, tooling, etc. are mounted to a linear actuator that is mounted parallel to the ground. The actuator will decelerate at a known rate per the parameters in the servo controller. I am most interested in comparing two different styles of designs (plates, tooling, etc.) hanging from the carriage, off this linear actuator. Specifically once this max deceleration occurs, the corresponding displacement value. This is indeed a dynamic problem but my question is if it is reasonable to apply this max deceleration rate as a horizontal negative acceleration within a 'STATIC' FEA to obtain some idea of max displacement and way to ultimately compare designs. I sort of understand the governing equation of motion but do not fully understand the short comings with this approach as compared to a more involved time dependent dynamic analysis. For reference I have access to Solidworks FEA. Thanks for any feedback!
