linetype issue
hayeska
46
My lineype is set as continuous in the Layer Properties Manager but shows as dashed when drawn.
When listed, the property is dashed for line type.
I can change the property of the line using DDMODIFY.
This happens to all layers no matter what linetype is designated in the Layer Properties Manager.
There must be some type of overide.
Any solutions?
Thanks in advance
There is a setting for "current" linetype, as there is for color.
I believe that setting (variable) is "celtype", you should set it to "bylayer".
It was set to dashed.
Don't know how it changed.
