Link drawing property to model property
drillrig
33
Hello all,
Is there a way to link a drawing custom property to a custom property in the part/assy? I can't seem to find the answer anywhere in this forum.
In the File-Properties-Custom tab the syntax I thought would work was $PRPSHEET:"TITLE1" where TITLE1 is the property in the part or assy. But this doesn't seem to work.
Thanks in advance!
- Chris
A couple of quick notes…
The answer to why is likely nothing better than the code that evaluates the custom properties is different than the code that evaluates the note text and the custom property one does not have the functionality that we would like.
The main down side of the macro is that it is not associative. If the properties in the model change, they will not automatically update in the drawing. The macro will need to be rerun.
The property names TITLE1 and TITLE2 suggest you have properties for two lines in the title box. The text boxes in later versions of SolidWorks (2007+?) can hold multiple lines, allowing you to get by with just one property. If you feel the need to control the line break, you can hold down the alt key and punch in 0010 on your number pad to insert a line break character.
Please submit an enhancement request for this functionality, the more people who do, the more likely we are to get it.
Eric
My bottom line: Why do I need to run a macro to do this when using the $PRPSHEET syntax works just fine in drawing notes, title block, etc?
One reason is probably linked to single-sheet vs multi-sheet drawings. The title block and any notes on a drawing sheet only refer to the model placed on the active sheet when $PRPSHEET is used. In a multi-sheet drawing, the drawing CP's refer to the whole document (all the sheets) ... so the $PRPSHEET:"TITLE1" syntax does not tell the CP which model it is referring to.
You can also use $PRPVIEW:"{property name}" to link properties to a model in a drawing view.
Tick,
I can't get that to work in the drawing CP. Would you mind posting an example?
drillrig,
"I will dig into it and see if I can get it to do what I want."
The macro I posted should already do what you want. It has been changed to propagate the TITLE1 property.
It doesn't work for linking properties. It's for putting properties in notes. It's the end result of what is inserted by the custom property button in the note editing dialog.
Thanks all for your replies. Looks like I'll be using the macro.
- Chris
