Oct 8, 2014 #1 euao Mechanical Sep 30, 2014 13 ES Hi friends I'm working with models that with assemblies and several components and I have the problem that the links are lost if I move the folders. Is there any way to work so that these problems do not occur? Thanks Eauo
Oct 8, 2014 #2 Rummo Mechanical Aug 29, 2014 16 TR try to put all the components in one folder ,then make your assembly . Best Regards Muhammed Rummo - Syria Upvote 0 Downvote
Oct 8, 2014 Thread starter #3 euao Mechanical Sep 30, 2014 13 ES Thanks Muhammed, but is not possible. The components are linked to several Assemblies. Upvote 0 Downvote
Oct 8, 2014 #4 JohnRBaker Mechanical Jun 1, 2006 35,347 US Then set up your Load Options so that you've define search paths to the various folders where the Components are located. John R. Baker, P.E. Product 'Evangelist' Product Engineering Software Siemens PLM Software Inc. Industry Sector Cypress, CA Siemens PLM: UG/NX Museum: To an Engineer, the glass is twice as big as it needs to be. Upvote 0 Downvote
Oct 8, 2014 #5 PhoeNX Mechanical Mar 2, 2010 869 AU See the attached image for what John was referring to for NX9. It's same in other versions, just where you find the Load Options dialog is different. Anthony Galante Senior Support Engineer NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3 NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.3, NX10 Beta Upvote 0 Downvote
