MittenBuild
- Aug 26, 2023
- 3
We are in the middle of a new construction and it is being suggested to use a steel lintel fastened to the wall studs (cripples under windows) above the front porch to carry the load of the brick above the porch. Has anyone seen it done like this? Seems like a lot of weight to be relying on a steel lintel bolted to a stud wall to individual cripple studs and hoping for mason to hit the studs dead on. The start of the porch roof is above the rim board which is engineered rim board since engineered floor joists were used. The smaller gable cantilevers out a 1’. This is in Michigan, snow is a factor and in Seismic zone 1. See attached pictures for reference. *Note the blocking between the mono trusses are just nailed into the wall sheathing and are not structural as depicted in photo from below and can be seen from window picture looking down on porch in between the trusses.
Thank you.
Thank you.
