I am tring to determine if there will be problems with air entrainment in the pipe and/or pulsations for the following problem:
I'm working with a project on an offshore installation (Norwegian sector). The storage tank for wax inhibitor is filled by connecting a flexible hose from the transportation pods in which the wax inhibitor is shipped. The company wishes to replace the hose with a permanent pipe.
The elevation difference between the pods and the storage tank is about 23 m and the line will be approx. 70 m in length. The line will have sections that are either sloped (minimum 1:100) or fully vertical. Of course, since elevation difference < pipe length most of the pipe will be sloped rather than vertical.
The storage tank is a vented atmospheric tank with four 2 inch vents. The inlet to the tank is not submerged, so air can enter the pipe via the tank.
The pipe is supposed to be 2 inch SCH 10 and has a maximum allowed design pressure of 18 barg (according to company piping spec).
The density of the wax inhibitor is 884 kg/m3 and the viscosity is around 10 cP.
I have calculated the maximum possible flow from the static height and a pressure drop spreadsheet (Darcy formula). The total length incl all bends etc have been taken from a preliminary piping isomtric. This gives me a velocity of 2.79 m/s and a flow of 23.6 m3/h.
However, this assumes a full pipe. There have been some discussions earlier on this forum regarding problems like this, for example thread378-81608. The thread descibes how vertical gravity lines can "gurgle" when air passes through the pipe.
My questions are: Will the pipe be liquid filled? If not, will air entrainment in the pipe cause serious problems with vibrations/pulsations? Is the "gurgling" a problem or will it just mean that it takes a while to establish full flow? Could one install a throttling valve at the end of the pipe to decrease the flow and the pulsation problems?
Some safety considerations (in case someone asks...):
The volumetric flow is to small to overpressurize the tank even if one vent is blocked and the tank is liquid filled.
The pods are equipped with a vacuum relief valve.
The wax inhibitor is not flammable according to the MSDS.
The storage tank is protected from overfilling with a actuated ball valve (closing time is 8 s to prevent hammer effects - enough?). The storage tank is also fitted with an overflow line.
The static pressure from the liquid cannot overpressurize the pipe.
For a picture of one of these pods, see
