Liquid/Molten Sulfur specific gravity
sfacchin
Chemical
May 13, 2009
19
S!
Anyone knows/has the variation of liquid/molten sulfur as a function of temperature?
Cheers
From the CRC manual:
The density at the melting point (115.21oC) is 1.819 g.cm-3
Between that temperature and 160oC use:
[ρ]t = 1.819 g.cm-3-0.0008(t-115.21oC)​
Surprizing you haven't asked about viscosities.
"We have a leadership style that is too directive and doesn't listen sufficiently well. The top of the organisation doesn't listen sufficiently to what the bottom is saying." Tony Hayward CEO, BP
"Being GREEN isn't easy" ..Kermit
S!
BigInch, my issue is with volume to mass conversion of a liquid sulfur tank.:)
Flow properties, in this case, are not my concern.
You're the lucky one.
