Liquid Slosh in containers 1
erickxxx
Aerospace
Dec 23, 2013
8
I am an individual inventor working on a system that eliminates liquid slosh in rigid containers. I would like to find out whether there is a demand for slosh elimination at all. All constructive thoughts and opinions are appreciated. Please help! [ponder]
If you can provide an economical solution to the bulk liquid trailer market (highway use) so that unbaffled tanks may still be used without adding much difficulty to the cleaning/sanitizing process (the reason that unbaffled tanks are favored for many commodities) you may have something. Ask any trucker about it. Every hour on the road feels like 2 hours worth of fatigue, and it's rough on the tractor, as well.
The only other place I can think where some improvement of this type might be useful is water tanks, either for potable water in aircraft (little demand, I would think, as the tanks tend to be relatively small), and water tanks on firefighting aircraft. I have done (engineering/STC) water bomber conversions on two different aircraft, and the tanks were mounted in the fuselage, and had pretty extensive baffle systems.
I currently work with helicopters that have similar systems, some of which even allow for a segregated tank with partial water drop for multiple smaller drops from a single fillup. (lots of one-way valves)
