Lisp - convert numbers to evens 1
danielhyde
23
GB
Can anyone tell me how to convert odd numbers in to even numbers in LISP?
I have a lisp routine which returns both even and odd numbers (0,1,2,3 up to 9) and I need to return and function that will round the figure down to the nearest even number, e.g.: 1 to 0, 3 to 2 etc.
Can anyone help?
Thanks in advance for any help
Dan
(* (fix (/ NUMBER 2)) 2)
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
HI borgunit,
I am getting an error:
; error: bad argument type: numberp:
I have been tring it as follows,
(XSTR (fix (/ XSTR 2)) 2)
I am tring to overwrite "XSTR" which is either odd or even, with a new "XSTR" value which is only even.
Can you tell me where I am going wrong.
(setq XSTR (*(fix(/ XSTR 2)2))
.. Henry Ford
Oops, I did not look at your error closely. It looks like you are trying to do mathematical computation on a string and not a number. atof convert the string to a floating number.
Try this..
(setq XSTR (atof XSTR))
(setq XSTR (*(fix(/ XSTR 2))2))
.. Henry Ford
hi borgunit,
It know works, it was a string!
Thanks for the help.
Dan
