LISP ROUTINE FOR GROUPING 1
frankreid
92
As my customer requires that I use 2009 LT, I've come to enjoy using the GROUP command. I also have FULL 2008 and know that there is no command like the one in LT. The one in full Autocad requires a name be created just to do the grouping, whereas, in LT it's much simpler, very much like the tool in MS Word.
I was wondering if any of you creative LISP programmers out there have/could come up with something like this.
Frank Reid
Are you stating that the GROUP command does not exist in ACAD 2009 LT or amI misunderstanding your thread?
Chicopee, The simple and useful GROUP command as we all know it in LT does NOT exist in full AutoCad - any version. The one in full version is much more elaborate and not as handy. Thus my question.
Frank
Vmichl, I went to Xanadu and downloaded the file. Now I don't know how to get it into my ACAD 2008. It isn't a lisp file (.lsp) so I'm not sure what to do. I haven't loaded a Lisp routine since version 12! Need some help here.
Frank
Load a "vlx" file the same as you would a "lsp" file.
1-Using menu, Tools>>Load Application; or
2-drag & drop file into AutoCAD window
CarlB,
That worked exactly as I wanted. Thanks a lot!
Frank
CarlB, I have been using the GRP.VLX file but I notice that I have to load it each time in every drawing. How can I make it permanent or how can I make it load with ACAD startup.
Thanks,
Frank Reid
Put it in the "startup suite" (suitcase icon, using "tools" "load application")
Yes, you can use APPLOAD (the briefcase icon) to load the LISP file "permanently". Or just use e.g.:
(load "GRP.VLX");GRP
in your menu macro (CUI). You can also use CUI to assign a keyboard shortcut to this command - e.g. Ctrl+Shift+G.
Vladimir Michl,
