Lisp to define points for cnc path
57
How do I change the following Lisp program so that the first number is the x-value and the second is y-value but shows as 2X the value(is diameter instead of radius)?
(DEFUN C:pTT (/ osm p1 x y s p2) ; ID a point, place coordinates text
(graphscr)
(setq osm (getvar "osmode"))
(command "osmode" 53)
(setq p1 (getpoint "\nSNAP to point to be ID'd: ")
x (car p1)
y (cadr p1)
s (strcat "(" (rtos x) "," (rtos y) ")")
(command "osmode" 0)
(setq p2 (getpoint p1 "\nPick point for end of Leader: "))
(COMMAND "DIM1" "LE" p1 p2 "" s)
(command "osmode" osm)
(princ)
Thank You
So you want the y value to actually report as 2xy? (not sure how this works for labelling a radius though...)
Then this:
Code:
(DEFUN C:PTT (/ osm p1 x y s p2) ; ID a point, place coordinates text
 (graphscr)
        x (car p1)
        y (cadr p1)
        2y (* 2 y);;added this line
        s (strcat "(" (rtos x) "," (rtos 2y) ")")
 (princ)
I don't think I explained the problem well.
We want to define the contour of a formed Roll from a "zero" point. This "zero" point is on the centerline axis and on one face of the Roll. We need all tangent points of the contour so that we can write a CNC program from these points. Each point is a distance from the "zero face" and on a radius(but the program needs the Diameter-therefore 2 times y value).
I hope this clears up the question.
TIA
11991
Nope, not clear to me. I think I'll need a sketch. Maybe because the CNC process is not clear to me. The main thing I'm not grasping is the reference to "y" as a radius. The first routine merely labels the x & y coordinates of a picked point. My editited routine used 2*y in place of y. If not a sketch maybe an example describing a point and coordinates, and how it should be labeled.
While diameter would be plus and minus y
I do not understand why 2y would define the
diameter from the zero axis. If your input
is the diameter instead of the radius, then
you want to define y as the diameter divided
by 2 or diameter times 0.50 for the y value.
I had problems with the link, couldn't download.
And a question for you- did you try the lisp routine I posted? It did incorporate the "y=2*y" you keep mentioning. :)
I can not get it to load. It shows it loads but does not work. I look at the Load Applications function and it is not there, however it is in the Startup Suite and the Support File Search Path.
I also tried altering the PPP Lisp from above with your changes with no luck. I only get the (x,y) values.
I think the problem is in how you are saving the file or loading it. If I copy and paste the above code into AutoCAD's command line (a shortcut way of loading code), then type PTT, it labels points with 2 times the y value. Try pasting the above code into notepad, save with a ".lsp" extension. Remove other routine from startup suite. Load this new routine. Should work.
Oh yeah, if you just want to edit yours with my changes, I didn't flag an important item you might have missed:
Thank you, CarlB. It works as you said.
11991
