List of components in an assembly
jayanthi
6
Hello ProE Gurus,
I would like to know, if there is any solution to just list out all the components( including suppressed)that are there in an assembly, WITHOUT opening the assembly in ProE.
I am just curious to know, is there any round about method to handle this using command prompt.
I heard Unigraphics has some feature called 'UGPC' for similar purpose.
Thank you,
regards,
Chakravarthy JSK
If you have INTRALINK, select the assembly in question and then select REPORT --> BOM --> REPORT.
Hope this helps.
maybe only a drafter
but the best user at this company!
just noticed this doesn't show suppressed items.
Sorry!
Hope this helps.
Hello again.
If you select REPORT --> BOM --> REPORT and then highlight the assembly in the new window, one of the icons is CS Relationship Report, select this and all files will be shown, including SUPPRESSED items.
We are using Pro-E 2001 and INTRALINK 3.2.
Is this any help?
Hope this helps.
Only Drafter,
I do not have INTRALINK. IS there any other way to do it, even with out INTRALINK?
Is INTRALINK demo license available for download? May be I can give an attempt.
Thank you,
Chakravarthy JSK
