Prot123
- Jul 25, 2018
- 42
What is your experience with clearing LL faults at the end of rural distribution feeder with low fault current. The problem is with fault level so low, there is no discrimination against load current. Also, what are the concerns with such a low LL fault going undetected? If this fault evolves flashover to ground then earth fault protection will clear it eventually. Some of my colleagues seem to not worry about the LL fault because of this? What are your views?
