Load Options (All components vs Structure only)
rmorgan890
70
0
0
I'm using NX 9.
What is the difference between opening an assembly with Load Options set to "All COMPONENTS" vs "STRUCTURE ONLY" and then opening the entire assembly in the ASSEMBLY NAVIGATOR?
The "all components" option will attempt to load all the components of the assembly. The "structure only" option will not load any components, but you will see the assembly structure in the assembly navigator.
www.nxjournaling.com
Cowski,
I understand this, but when I open the assembly in the Assembly Navigator using "STRUCTURE ONLY" I'm getting different results.
rmorgan890 said:
...when I open the assembly in the Assembly Navigator...
If you see the main assembly in the navigator, it is already open, is it not? Are you talking about loading a sub-assembly? What exact steps are you taking to open the assembly and what results are you getting? (some screenshots would also help)
