VT17
- Apr 27, 2018
- 14
I have question regarding load path around an opening of a t-section made out of round hollow sections.
So I’m doing the structural design a sculpture that is essentially cantilevered from the ground (like a pole). The connection that makes the transition from the rest of the sculpture into the vertical support is a T shape moment connection. Before this was accomplished by welding a round HSS vertical post to a horizontal round HSS member and making the adequate checks under table K3.1 of AISC 360-10 and using an adequate weld. Furthermore, the horizontal HSS was going to have a drilled hole concentric with the vertical HSS to run electrical conduit inside the HSS sections. However, now we will be casting pieces instead of using HSS sections so this T shape will be one uniform piece similar to this in shape ([URL unfurl="true"]https://www.oilybits.com/316-stainless-steel-reducing-tee-150lb-bsp.html[/url]). My question is whether it poses a problem to have that opening in the horizontal section the size of the inside diameter of the round vertical “stem”? The horizontal section is experiencing shear in both orthogonal local axis, moment in all three axis, and axial load simultaneously that need to transfer to the vertical stem. Since this is all one piece, the load should travel from the horizontal section to the vertical section around the opening correct? In other words, for all those loads I mentioned, I should be able to use the section properties of the full round section for the horizontal member correct? Also is there any stress concentration that occurs at this location?
Thank you in advance if you read this far and for any input you provide.
