azcats
- Oct 17, 1999
- 692
Is there interoperability between tnxTower and RISA foundation? I'm struggling to get the envelope of reactions from tnxTower, thru (or not) RISA-3D and into RISA Foundation.
I can open my tnx model in 3D. Help says that I need to make sure that the each BLC is assigned to a load category. But I've got ~20 wind loads each at different angles around the tower. If I add them all to category WL, when imported into Foundation the reactions are all stacked on top of each other as one load case of WL. Is there a way to keep the reactions from different angles of wind load separate in the transition from 3D to Foundation? Or is there another pass thru? Or do I just need to do this the old fashioned/tedious way?
Help and/or input appreciated.
