I'm designing a carrier bearing support for an automotive intermediate axle shaft. The non articulated intermediate shaft will couple to a Lobro CV joint close to the carrier bearing. I wish to learn the magnitude of force to be considered in the axial plane of the carrier bearing. That is, force contributed by the CV joint when it is transmitting torque while at it's maximum angle of 25 degrees. I expect it to be somewhat proportional to transmitted torque and joint angle.
