Local dynamic stiffness?
mdina2nl
Automotive
Apr 4, 2008
1
DE
Dear Nastran comunity,
I would like to know how I can plott the local dynamic stiffness of some nodes in my body in white model?
I have simulated the model with SOL111 and 108 and Nastran 2008.
For example if I excite the node with id 100 with SOL111, with a unit force (1 N), in the model and I get a displacement about 0.0001mm on this node. Then it means that I have a lokal dynamic stiffness of 10000 N/mm or rather 10 N/m.
Is that right?
Thnx,
Dina
With kind regards,
Dina
Hi Dina,
Yes u r right. But, corresponds to the which frequency you are calculating that stiffness is important.
Since, from basic definition, dynamic stiffness is stiffness measured at each frequency.
Hope this helps.
Kumaravel Saravanan
