Local Vs global stress and fatigue analysis in fea analysis
krzychu1904
Student
May 10, 2024
1
Hello
I have three questions about FEA analysis according to EN 13445 (though I believe these issues are similar in ASME).
The first one: during stress categorization, local and global stresses should be distinguished. Do you know of any simple method for doing this? I read that there is a formula to set the radius where local stress occurs. But how can I interpret this in ANSYS? I’ve seen some people create new edges around discontinuities, but if you have dozens of junctions, it becomes very time-consuming.
AND I would also like to ask about singularities at the place of geometric discontinuities. in these places there is a greater yield point, (F*1,5 or f*3) however when we make a mesh refirment, the stresses tend to infinity. When doing calculations according to the norm, can we ignore the peak stress as a singularity? Or should we rigidly stick to the established yield point, even if one node exceeds it. I mean ignoring it due to Saint-Venant rule.
The last question is simpler: when should I perform fatigue analysis? In the table with assessment criteria, it states "only if required."
I can speak in the context of the ASME rules. Regarding global vs local - I would assume that you are talking P_m vs P_L. P_m is a hand calc. Never use FEA to calculate a P_m. And as for answering the question about how local is local - there are limits on the extent - read the rules.
Singularities are handled by the stress liberalization process.
Please read and then reread paragraph 5.2.1.2 of ASME Section VIII, Division 2, Part 5 when it comes to stress linearization and categorization.
Fatigue analysis is performed when a fatigue screening assessment does not pass.
The definition of P_m is (from 5.2.2.2(a)(1)) "is the equivalent stress, derived from the average value across the thickness of a section, of the general primary stresses produced by the design internal pressure and other specified mechanical loads but excluding all secondary and peak stresses". What is that but P*r/t, M*c/I, and F/A? It's a hand calc.
I agree but for specific geometries like the nozzle/header assembly of my previous post subjected to external loads, i think it will be difficult with just an hand calc
For those complex geometries, see 5.2.1.2.
5.2.1.2 For components with a complex geometry and/or complex loading, the categorization of stresses requires
significant knowledge and judgment. This is especially true for three-dimensional stress fields. Application of the limit load
or elastic–plastic analysis methods in 5.2.3 and 5.2.4, respectively, is recommended for cases where the categorization
process may produce ambiguous results.
It's fine we're doing elastic with the help of a software and our massive engineering judgement
