jartgo
- Oct 20, 2005
- 220
I'm looking for any successful design of a lockable grate that would be mounted inside of catch basins and manholes, just beneath the standard grate or manhole cover.
The application is for a prison. The standard grates have been attached to the frames with locking (McGard) bolts, but the owner also wants addtional locking grates inside the basin/manholes as backup in case the bolts are broken from traffic loads.
I'm working on a design constructed from stainless steel rebar, but thought I'd see if anyone in this community has run across this issue before.
Also, does anyone know if a material cost of $1000 per ton for 304 stainless, grade 60, #4 rebar is accurate? By my calculation, this translates to about 35 cents per foot. I'm really just guessing at the $1000 per ton though.
