mdcondro
Industrial
- Oct 21, 2008
- 4
Is there a way or a device to inspect for anaerobic loctite application on a screw threads after installation?
The assemblies I'm involved in building require loctite on every screw, followed by thorough cleaning which removes any traces of excess loctite. The method I have set up to assure that loctite has been applied is making the assembly operators record loctite cure start time on each part's mandatory history log. This is merely a "warm-fuzzy" rather than a mistake-proof method.
