Loft Error
Deflatormouse
7
I am trying to a relatively simple loft (or so I thought) but for some reason I am getting an error that I haven't seen before. The error is as follows, "Cannot Knit Sheets Together"
I read online a couple places that said this may be due to the fact that the profiles are too different and multiple (more than two) guide curves may need to be used. The profiles I'm dealing with don't really yield themselves very nicely to multiple guide curve because of the plane construction that would be involved. I was wondering if anyone is familiar with this error and could suggest a way to make this loft work or present a work-around.
I'm considering splitting the closed region into two more basic shapes and lofting them independently.
A screenshot is attached.
Suggestions?
Thank you,
Deflatormouse
I found a solution using surface lofts.
By breaking the original profile into two separate loft portions I was able to create a nice guide curve from the edge of my first half of the loft.
If anyone can do loft like this without introducing surfaces left me know.
I attached a picture so you can see if you'd like.
Deflatormouse
 http://files.engineering.com/getfile.aspx?folder=23e894c7-11c8-4bbe-ad21-2acdfa2488f5&file=Loft_Fix.bmp
I don't mean to be rude, but images can be also saved as filename.jpg and upload and open much faster. Just a tip. :)
...and since we spend all of this time learning to communicate our design intent via 3D geometry, lets communicate with 3D geometry. Attach your file here.
If it is proprietary then simply make up a dummy file that exhibits the same behavior.
I would try using a "Boundary Boss/Base". Boundary features are newer and in most situations are superior to lofts. You can also use additional connectors to aid in the geometry creation without the need for extra guide curves. I hope this helps.
Rob Stupplebeen
rstupplebeen,
Thanks a lot - great advice.
Attached is a file containing the problem geometry. I'd be curious to see if anyone could avoid the "knit sheets" error and complete this problem using a loft. Anyway, thanks again.
 http://files.engineering.com/getfile.aspx?folder=d254acb7-831d-4634-9892-ba4ea1f20c81&file=Demo.SLDPRT
were you trying to knit the surface to the solid to create 1 body? If so you need to delete one face on the solid and cap the end of the surface. Or you can simply do the following.
Attached is a slightly modified model with a second boundary boss instead of a surface.
Rob Stupplebeen
 http://files.engineering.com/getfile.aspx?folder=47b9dea4-17e4-42fe-86be-b96a212170db&file=Demo-Stupplebeen.SLDPRT
