FPE22
- Oct 8, 2015
- 16
Hi everyone,
I have a dinning hall that has a ceiling height of 43 ft (13 m) which requires sprinkler protection as per NFPA. Ceiling panels are suspended at a height of 13 ft (4 m) above ground. These panels have width greater than 3.9 ft (1.2 m) and therefore are considered as obstruction to ceiling sprinkler spray pattern, and need to have sprinklers installed below them. These panels are distributed throughout the middle of the hall - at least 16 ft (5 m) between one another - and far away from walls or columns. The ceiling panels are supported to the ceiling above by four 6mm rods.
My question is, if my main pipe runs below the ceiling at 43 ft (13 m), then a long vertical drop pipe - around 30 ft ( 9 m) drop - will need to come down to connect to the sprinklers installed on the ceiling panels. How can I support these vertical drop pipes assuming they are 1" pipes? My concern is the vibration that will happen if the sprinklers connected to these pipes operate.
Appreciate your feedback.
