structural-eng
Can someone please explain to me what the last sentence in section 7.2.3 of ASCE 48-19 means? It states "Longitudinal seam weld shall have 60% minimum penetration (except as specified in Sections 6.3.4, 6.3.5 and 6.4.1 in this standard)." I understand that the exceptions listed require full penetration welds in certain locations. Is that section stating that the remaining portions of the seam weld that aren't required to have full penetration welds should have 60% (minimum) partial penetration welds? What is the equivalent size of a 60% partial penetration weld? In the case I'm reviewing the base material is (2) 1/4" plates oriented to form a 45° vee).
If a fabricator says every longitudinal seam weld is fabricated with 100% CJP for the top and bottom 6" and a minimum of 80% PJP for the remainder of the seam weld does that meet the requirements in section 7.2.3 of ASCE 48-19? I don't see anything in ASCE 48-19 about sizing the longitudinal weld, just these welding requirements which makes me think you can design the tapered pole per ASCE 48-19 as long as it's welded as noted.
