Looking for a Coarse Steel Grit Blasting vender????? 1
ljsanders85
7
I need to find a company that can perform a steel grit blast on some Ø0.600" O.D. X 6.00" LG shafts. The spec for the grit is SAE G40 angular steel grit, and the company must be able to supply certification for the blasting opperation. I am located in Michigan, if anyone knows of a reliable company please let me know asap!!! Thanks
I don't know of any job shops in your area that can do the blasting. I would go about by checking with a manufacturer of the grit like ErvIn Industries to give you some leads. If that don't work call Metal improvement to see if they can handle your job.
Next in line I would contact the suppliers of the blasting equipment and see if they can help.
and last but not least Ask.
