Looking for a Heat Conducting Transparent Material for Very Hight Application
morphers82
Materials
Jul 23, 2015
1
So I am looking for a material, not necessarily a polymer, but one that can withstand around 1100 to 1500 degrees F without melting or burning.
It should conduct heat very well.
It should also be thin and flexible that could possibly be rolled up and would unroll and flatten easily.
It would also be good for it to be atleast semi transparent or fully transparent.
And this material would need to be mass produced for consumer use so it cant be like 1000s of dollars per sq ft, more like $5 or so.
Is there such a polymer that has these characteristics?
Thanks You
There are no polymers that fit your need. Mica sheets might be suitable.
As well as Compositepro's suggestion you might also have some luck looking at geopolymers (not polymers in the usual sense). Some info attached but may be worth googling the topic.
 http://files.engineering.com/getfile.aspx?folder=0ac386ee-9b10-4447-9ec1-3df07dc7fc0a&file=Geopolymer;_Ultra-High_Temperature_Tooling_Material_for_the_Manufacture_of_Advanced_Composites,_Davidovits_&_Davidovics.pdf
Download link doesn't seem to work, but here is a direct link to the paper:
Doesn't look particularly transparent, though.
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
Thanks IRstuff. I had a comma in the filename, which seems to screw up 'attachments' even though PCs and Unix usually don't mind them.
The OP's material requirements are quite steep, even without transparency! A 1000+°F flexible material for less than $5/sq.ft...
Maybe a glass fiber cloth? Probably good for 1300°F. Maybe $2/lb.
This should work: Link
Porbably worth tracking this guy down for some advice on it: [link data:image/jpeg;base64,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]Link[/url]
But seriously, I can't think of anything that will hit those properties and be low cost, although such materials probably aren't as scifi-ish as might be thought Link
