Looking for Help with Air Cylinder Selection for X-Z Slide Configuration
Ram-Design
1
Hi everyone,
I'm currently working on a new project and need some guidance in selecting the right air cylinder setup. I’m using an X-Z configuration with two air slides:
The Z-axis applies a downward force of 525N, carrying a workpiece load of 4kg. The X-axis does not need to exert the same force—it only needs to hold its position rigidly while the Z-axis operates.
My main question is:
Can the MXW20-225B-M9BWL on the X-axis handle this configuration, particularly in terms of rigidity and holding position during Z-axis actuation?
I'd appreciate any insights, experiences, or references that can help with the selection process.
Thanks in advance!
Air is not very rigid. Compressed air is somewhat more rigid. When rigidity is important hydraulics are used.
An electric positioning screw drive is probably more suitable for the task. Next up, a servo motor driving a pinion against a toothed rack.
Air driven systems are good when there is a need for rough positioning, such as air-ride suspensions, that retain a good amount of travel in response to external loads or systems that have two end-points and little need for precise location in between.
