Looking for the smallest relay, 5VDC coil, 20A@120VAC
hrc
104
Subject says it all....I need a SPST relay, PCB mount, that can carry 20A@120VAC, with a 5VDC coil.
Needs to be as small as possible. I'd prefer to stay away from solid state relays.
Where have you looked? We wouldn't want to suggest places you have already looked....
Aromat,P&B,Omron so far
I've had good luck with the PB (now Tyco) T90 Series. The NO contact does well with 20 amps but we do switch the current on/off with a triac so the relay is actually a dry contact.
