buchacho
- Sep 25, 2007
- 12
I am trying to think about this scenario, but not sure what to think. Let's say you have a loosely held (low friction) disk object held between two clamps and spinning on a hub at a certain RPM. As the disk-shaped object is spinning, it is perfectly balanced on its X-Y CG. Does the rotating disk have a tendency to remain balanced with a rotational inertial force (ignoring friction)? If so, how would I calculate what the "self-balancing" force would be?
