Logan82
- May 5, 2021
- 212
I have received the results of a Charpy Impact Test on a steel beam made of A7 steel. The test indicates that the steel is brittle (8 J at 0°C). My beam is utilized mostly in shear, and slightly in bending. CSA S16-19 31.1.1 indicates that "Brittle fracture is a fracture mechanism taking place in the presence of tensile stresses and accompanied by limited or no plastic deformation before fracture at a stress level significantly lower than the yield point of the material".
Does having a low ductility also have an impact if a beam works primarily in shear?
