smart143
- Feb 3, 2012
- 78
My welder has welded a test coupon for PQR in Duplex (UNS S31803) of 30 mm thickness with double welding .The electrode used was E2209-15 of dia 3.2 mm, the ferrite reported on MTC of electrode is 36%. I did not measured ferrite content during & post welding in weld, the coupon was subsequently solution annealed at 1140 deg C for 75 mins.
The test result reported by Lab shows ferrite in weld only 25% whereas HAZ shows 51% & PM shows 59%. Now we need compliance as per NACE MR0175 where in ferrite in weld required is between 35-65%.
What could be the reason for low ferrite in weld, the heat input during welding was 0.8-1.0 kJ/mm.
What I will need to do to meet the 35-65% ferrite level. I do remember that ferrite in weld of austenitic tends to reduce post solution annealing, does same phenomenon occurs in Duplex steel?
