Nebur98
- Dec 12, 2009
- 16
I noticed that when I change the view with the space navigator the movement appeared somehow jerky.
Further investigation using a software that shows the framerate of DirectX/OpenGL viewports (FRAPS) shows that when rotating/panning with the normal mouse I get exactly the desired 60fps (v-sync!).
In contrast when I move around with the space navigator nx delivers exactly 40fps instead of the expected 60fps!
I performed the tests with parts that surpass 100fps with disabled v-sync, so the GPU horsepower to display the 60fps is easily available.
Made the same test with MastercamX on the same machine/config and there I get 60fps regardless of using the space navigator or the mouse to move/pan, so it must be related to Nx somehow.
Anybody out there with a solution or a similar problem? I know its not a major problem but I would really love to get a smooth movement in sync with the screen refresh rate. It looks like a stepwise movement instead of a flowing motion and I'm used to move the parts around continously when working so it really hurts my eyes.
This is my config:
- Core2Duo 2,4Ghz (cpu throttling intentionally disabled to avoid timing problems in applications that expect a constant clock)
- Quadro Fx3700 with v-sync on
- Win XP 32
- NX7 with MP2(of course 32bit version)
- Space Navigator with latest driver and NX plugin installed (removing the nx plugin did not change anything)
I would appretiate any help.
Cheers,
Nebur
This is my config:
- Win XP 32
Cheers,
Nebur
