Typically, Exxx6/7/8 electrodes for SMAw are LH electrodes because of the redrying which reduces the diffusible hydrogen in weld metal (by reducing moisture in coating). The AWS/ASME section IIC only specify a max level off 0.6% by weight for the misture in coating for LH consumables as per SFA 5.1 (CS electrodes)
However in case a tighter tolerance on diffusible hydrogen is desired, a supplementary designator can be used which signifies the maximum diffusible hydrogen in weld metal.
For FCAW, since the flux is in the core, the chances of moisture ingress is greatly reduced, and hence most of the wires available would give a low hydrogen weld deposit. For SAW, the basic fluxes would give low hydrogen weld metal and the acidic/rutile fluxes used for higher welding speeds generally would be with higher hydrogen levels in weld metal. Typically the specifications for oil and gas offshore platforms, give a limit on the hydrogen content upto which they would consider the weld metal as low hydrogen. Typically I have seen limits upto 15 ml/100 gm or below being designated as low hydrogen, though for specific applications like higher strength materials, the limits would be lower at around 8ml/100 gm.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
email: sayee_prasad@yahoo.com
If it moves, train it...if it doesn't move, calibrate it...if it isn't written down, it never happened!
