bebme
Bioengineer
- Apr 11, 2008
- 19
I am trying to run a 2D static contact analysis between a cylindrical rigid material and a flat low modulus linear elastic material (20 MPa) subjected to a fairly large force (2000 N). I have solved the excessive distorted element problems but am now having trouble with solution convergence. I can get it to run to completion work with a 200 MPa modulus but the more I lower the modulus, the harder it is to get the model to converge. Now my message file states that the force equilibrium have not been reached mainly due to the displacement correction not being acceptable (default settings). I have tried decreasing the step size and increasing the cutback limit. Has anybody else had similar problems and determined ways to solve them?
