bws222
- Feb 19, 2011
- 1
I was hoping someone with experience in low pressure sewer design could help me. We are working on a small lps system to serve roughly 30 houses. The best reference I have found is the EPA's manual on alternative sewer systems. My question is about calculating the design flow for pipe sizing.
The EPA mentions two methods for this; probability and rational. The probability method is based on probable number of pumps running simultaneously and pumping rate (only recommended for progressive cavity pumps). The other method is the rational method which is based on flow rate/dwelling unit.
We are proposing a centrifugal pump. I have worked on a smaller lps system in the past and we had access to the FE Myers Collection systems manual and they used the probability method for centrifugal pumps as well. Just wondering what method others use for centrifugal pumps. Also I was wondering are zones required when using the rational method. My understanding is that zones are set up when the probable number of pumps operating simultaneously increases by one.
Also any other reference for low pressure sewer would be great.
Thanks for any help
Thanks for any help
