Hi everyone,
We are installing a new low pressure 2-phase separator in the field. The operating P is around 120 psig. The pipeline and the vessel are to 1375 psig @ 185 F.
I had a discussion with another engineer on how best to protect this vessel. His point is that since the operating P is very low compared to the design, protection using PSV provide enough protection? His logic (and reality) is that we should not see a pressure above 300 psig (at worst) and the vessel is designed to 1375 psig (PSV also set at 1375 psig).
However, I feel that, even though we may never see a pressure over 300 psig, we also need high alarms just in case. We don't want the remote scenario of extremely high pressure to happen and we only have the PSV to protect us. If we have alarms, we will be able to respond to any unplanned increase in pressure before the PSV goes off. Also, what if the PSV fails? That leaves us with no layer of protection. Hence, the alarms will provide another layer of protection.
Am I correct in wanting multiple layers even though we realistically don't expect to use them? Or should we just go with only the PSV and cross our fingers that the never need it?
