dakers
- Dec 30, 2014
- 13
I am currently working on a project and I am having difficulty finding structural steel to be used on the job. The final location for the heater is in Siberia and the customer has asked that we use low temp carbon steel and that all steel be rated for -56degreesF. Currently we are purchasing structural shapes of A572 GR50 and having them heat treated and some of the steel is still failing our Charpy Impact Test requirements. We cannot afford to keep purchasing material and simply hoping that it passes. I have found other grades such as A203, A537, A533 that would seem to work fine but I cannot find a steel distributor in the U.S. that has structural shapes of these grades. I am currently looking into A588 as I was told it is very similar to A572 but has a better history of passing impact test and is readily available. If anyone could please offer any insight or alternative material it would be greatly appreciated. Thank you! - Dakers
