aggieengineerrmb
- May 27, 2003
- 28
I have a very low temperature application, -70F, which may not be truly cryogenic, but appears below the level that most valve companies are experienced. It will almost never see those temperatures, the vast majority of the time it will be above freezing. We have had some companies come back with what appear to be almost standard trunnion valves, some utilize spring entergized lip type seals for the stem and valve seat ring, and others have very exotic extended bonnet designs. Of course, the price-delivery increase in direct proportion to how non-standard the design is that they offer.
It's very difficult to sort through all the claims from the different MFG's to determine what is really required. Does anyone know of a good reference on the design of cryogenic valves, or as a minimum some basic information you have gained from experience?
