Mike666
Military
- Sep 27, 2006
- 2
hi,
I need to design a box that should be totally sealed from water and water vapor.
Although i know that the best materials for that purpose is metals
(for example aluminum (MVTR=0.001 g/m^2/day))it can't be a metal.
The solution I was thinking about was Ceramic ?
Or maybe a plastic with very low MVTR?
What material has the lowest MVTR except metals?
Can I build a composite box from fiberglass (that will give the strength) with a sealing laer made of ceramic material?
thanks
thanks
