I'm looking for a storage tank of 100-500 gal. capacity to store liquefied hydrocarbons mix with pressure of 330-350 psig at 115F. This pressure is above a commonly used tanks with 250 psig limit. Any suggestions where to find a tank or info about it? Thanks.
Thanks, but this pressure is higher than local butane/propane distributors handle. I've checked with them and didn't get any helpful advice. Any other ideas? Thanks.
Thanks MJCronin for the reply.
340 psig at 115F is the calculated pressure of my hydrocarbon stuff. Too bad the propylene cylinders will not fit.
First, I need a small, like under 1,000L, cylinder for development stage, then a larger one, like 4-8K litres. I hope to find ready avalable cylinders as making a special one(s) is not economically feasible.
This is likely going to be a custom vessel - as Cronin stated, almost all LPG tanks are 250 Psig design. You're going to have to find a shop that can build you one or source a used one somewhere.
This still sounds a little strange - how the heck are you going to transport such a wild product? Most highway LPG transports are the same pressure - 250 Psig.
