lpile
5747hazel
43
Can L pile calculate reinforcing for concrete pile with a circular section? Thanks
Lpile will provide compression capacity and moment demand, from that you can calculate the required steel.
thanks. what do you use to check or calc the reinforcing for the circular section?
I used to use PCACol. I don't know if it still available or not. But there are many programs can do that.
that was what I have been using. I am kind of semi retired. can't believe I forgot pca col.
LPile 2019 will calculate nominal moments for circular RC sections.
If you want to do it outside of LPile there are some spreadsheets out there.
I've messed with:
[ul]
[li]'ShortCol' from yakpol.net[/li]
[li]'CrossSectionAnalysis_V0403' from Robert Niall at rmniall.com[/li]
[/ul]
But LPile is my go to anymore.
If you have access to CRSI handbook, that will help too.
