I am part of a team working on an elevated roadway for an international airport. We have restrictions on the raodway depth to accompdate floor to floor heights appropriate to boarding aircraft and 13'-6" minimum clearance for the lower roadway. We compared the AASHTO LRFD Specification and the Standard Specification and found that the combination of the lane and truck loads in the LRFD spec has some impact on the girders but the big hit was in the bents. Since the lower roadway runs parrallel to and below the upper roadway, the bents have a 62-foot span between columns. Our worst case bent has 105-foot span girders on one side and 30' span girders on the other side. Since the LRFD spec also requires that the trucks be located in trains with 50-foot spacing between trucks, the reactions to the bents are far greater in LRFD than in the Standard Spec. We found that the design moments were increased by a factor of three. Has anyone run across this large of a discrepancy between designing by LRFD and designing by the Standard specs? Did we miss something?
